Browse Forums Flooring & Floor Covering 1 Oct 22, 2013 8:54 am Hi. I'm diy tiling my brick stairs atm. There is a 1cm gap between the two brick walls...see pic. What should i do here...use a tile edge to cover gap or put mortar or grout to cover gap? I thinks its been left for drainage. Also do i grout where the step tile meets the riser tile or should I use silicone? http://s1312.photobucket.com/user/racha ... %20Uploads Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4934 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19461 2 7691 |
