Browse Forums Flooring & Floor Covering 1 Jun 11, 2013 8:20 pm We have found an external tile that we love....can't find an internal equivalent Any reasons why we should/shouldn't use the external tiles inside ( kitchen lounge, living hallway) Wondering if there would be issues with cleaning.... Re: External tiles used inside....? 2Jun 13, 2013 4:56 pm Jen I would not use them indoors it is going to drive you nuts trying to keep them clean. Everything will stick and look ugly in no time. As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17877 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18302 Before you rip it up, if you can in the grout lines, drill some holes and pour/inject techgrip by sika. I have used it to bond mdf to timber, but in the process it dripped… 1 4294 |
