Browse Forums Flooring & Floor Covering 1 Jun 11, 2013 10:50 am This is going to be for a garage that I have turned into a games room. have a couple of pinballs and arcade machines. Want to turn my concrete into a softer, warmer area. Recommendations? Have looked at click wooden flooring from Bunnings at around $15/sqm. Thoughts on this or anything else. Area is probably 30sqm, Thanks. Re: I'm stingy help me find the cheapest flooring product 3Jun 11, 2013 9:54 pm Paint Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: I'm stingy help me find the cheapest flooring product 4Jun 11, 2013 10:06 pm The question is how much do you care what it looks like? McMats in bayswater vic has recycled carpet tiles very cheap. You need to go there and go through them but you can get very cheap flooring. They also sell second hand commercial carpet. I got a lounge and two bedrooms for $800 laid with underlay included with second hand carpet in a rental I had. Again you need to look as one area was a bit flattened but came up once it was cleaned. Re: I'm stingy help me find the cheapest flooring product 8Jun 12, 2013 9:40 am Back Pocket The question is how much do you care what it looks like? McMats in bayswater vic has recycled carpet tiles very cheap. You need to go there and go through them but you can get very cheap flooring. They also sell second hand commercial carpet. I got a lounge and two bedrooms for $800 laid with underlay included with second hand carpet in a rental I had. Again you need to look as one area was a bit flattened but came up once it was cleaned. Great...thank you, sounds like it could be perfect. Will check them out. Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6467 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6191 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15909 |
