Browse Forums Flooring & Floor Covering Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15884 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8288 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3270 |
