Browse Forums Flooring & Floor Covering Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6713 This link might answer your question. I had the same issue and it turned out to be the roller. https://www.sherwin-williams.com/painti ... %20coating. 4 18169 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8283 |
