Browse Forums Flooring & Floor Covering 1 Apr 24, 2008 12:54 am I've been figuring out the flooring for our house. We're having carpet upstairs and on the stairs, and carpet in my Mum's area (living room and bedroom) plus the formal lounge and dining downstairs. The rest of the flooring (besides bathrooms and laundry) will be wood, hopefully Blackbutt from the Boral Silkwood range.
Then comes the kitchen. From what I've read, it may not be a great idea to use wood in the kitchen. Don't really want to use tiles because it's really hard on your legs and back. Do you think it would look odd to have good quality vinyl in the kitchen only? I'd probably go for a tile-look one in similar tones to the tiles in the bathrooms & laundry areas. (I think the kitchen cupboards will be in graphite tones if that helps.) Thanks for any suggestions. Judie Re: Vinyl with timber? 2Apr 24, 2008 1:37 am Maybe! Its what appeals to you, and goes with everything else that matters. Other floor-coverings worth considering might be cork and marmoleum.
What will the kitchen floor lead onto? Be careful to create a smooth transition from one floor-covering to another. Ash. Re: Vinyl with timber? 4Apr 24, 2008 1:31 pm At work, we have vinyl in the open plan "kitchen" area. It looks great. Nice dark coour that almost has a dark stone look to it and is nice underfoot and very easy to clean. It even curves up at the edges and becomes the cabinet kickboards.
For my house design I'm having timber floorboards for the main living area and will either contiue the timber into the open plan kitchen or go for the same look as at work. Demolition August 2009, Construction Started September 2009, Completed December 2010 Hi all. I'm building a new house and in the past have always tiled the hallways, kitchen, dining, family room. I was looking at Dunlop Heartridge vinyl in the colour… 0 1710 ![]() Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 2446 We ordered the vinyl to install over the holidays and the company provided us with only enough for only a third of the job. They won't be open again for 2 weeks, can… 0 6088 |
