Browse Forums Flooring & Floor Covering 1 Apr 22, 2013 4:43 pm Hi All, Just to add to all my confusion, all the carpet shops have a different take on which underlay we need. I know that conventional wisdom is to buy the best underlay that you can afford, but a couple of the carpet shops have said that the second best underlay they have is the better choice. The two foam underlays that people seems to be quoting are the Airstep Steplux (9mm 95kg/m3) or Stepmax (10mm 120kg/m3) or the Dunlop Equivalents Springtred Extra (9mm 95kg/m3) or Ultimate (10mm 120kg/m3). I'm assuming that the brand doesn't really matter between these two because they both seem to be fairly reputable, but would the 9mm 95kg underlay be much different to the 10mm 120kg underlay? Re: Foam Underlay Questions 2Apr 26, 2013 12:18 am ANALYSIS PARALYSIS! That is what I get when I think too much about a single item. What I mean is that both would be fine. Should the price between the two be insignificant, then get the better one. Otherwise save your money and get the cheaper one. Just my 2 cents worth, Good Luck, Andrew Re: Foam Underlay Questions 3Apr 29, 2013 7:39 pm The denser the underlay the better...... Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4108 There is nothing in the various codes and standards that puts this requirement on the builder to do. I think that is what you are asking. Don't waste time trying to get… 5 2258 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8356 |
