Browse Forums Flooring & Floor Covering Re: Floor covering by third party? 6Mar 15, 2013 9:57 pm CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Re: Floor covering by third party? 8Mar 29, 2013 10:48 am I'm not sure that is the case. Though you might need to establish the following to comply with the code: Concrete as in concrete tanks that hold water up to and beyond 2.1 mtrs of 'head' and 100mm thick are waterproof. No house will ever hold more than 25mm of pooling water so this is not the issue. (House slabs are mostly 100mm thick.) The issue relates to the waterproofing of the 'wet areas' and can be 'overcome' by providing a waterproof membrane to 'bund' the wet areas. Hope this helps Where you are coming from is where you are going to... got it. thanks. I was looking for word ' Adobe' and added filter. all good. 12 14484 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16565 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 |
