Browse Forums Flooring & Floor Covering Re: Porcelain Tiles & Good Tiler - Perth 8Apr 22, 2013 3:18 pm Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Porcelain Tiles & Good Tiler - Perth 11May 01, 2013 9:51 pm Design by Greater Concept - modified version Evolution Court Build by Premiere Homes My build viewtopic.php?f=31&t=64854 Re: Porcelain Tiles & Good Tiler - Perth 15Jun 12, 2013 12:07 am Mike at Tiling Prodigy Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Porcelain Tiles & Good Tiler - Perth 16Jun 12, 2013 7:01 am Don't forget to check for optical hazing with pol porcelain tiles .. See page 1 of my thread .... and good luck For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Porcelain Tiles & Good Tiler - Perth 17Jun 23, 2013 11:16 pm hey guys just coming up to key handover and im organising painting and all flooring so im also currently looking for a good tiler in perth to do an area of 75 sq/m with 600x600 polished pocilian tiles if names and numbers could be posted or pm'ed to me that would be great... has anyone had bad experiance using pocilian tiles with sharp edges and tiles not layed at the right height??? had alot of warnings that if the tiler is no good the job will be no good Re: Porcelain Tiles & Good Tiler - Perth 18Aug 09, 2013 12:25 pm If anyone has good contacts for a tiler or painter in Perth I would love to hear from you. For tiling -we are needing to tile approx 110sqm in 600x600 floor tiles (living, dining, kitchen, hallway, entry). For painting - we are looking to have all internal walls of our home done professionally after handover. If you could please pm contacts/prices you have been quoted I would be most grateful Thanks!! Re: Porcelain Tiles & Good Tiler - Perth 19Aug 09, 2013 12:45 pm CC101 Magic tiles said that polished porcelain tiles need to be sealed. how much grout gap is recommended in rectified porcelain tiles? Our 600 x 600 rectified tiles have been laid with a 1.5mm grout gap. Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7042 9 24795 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7284 |
