Browse Forums Flooring & Floor Covering 1 Feb 02, 2013 7:39 pm Hi all I am after some advice on which direction to lay my timber flooring. We are using the Vintage Natural boards from HN. I am not quite sure which way to lay it at the top section of the T on our hallway and also in the kitchen (on the left of the plan) We have double cavity sliders which will be open more than closed so I need to work out how to flow the floor in to that area. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any advice would be greatly appreciated Re: Floor laying direction 2Feb 02, 2013 7:48 pm Ooooh we are going to use these too in a month or do. Would love to see how it turns out for you. We love the board and have high hopes for it! We will be laying ours vertically/longways the length of the corridor and matching that throughout (if that makes sense?!) Re: Floor laying direction 4Feb 15, 2013 12:06 pm Im thinking of changing the direction at the top of the hallway and also in the kitchen. Maybe I should just run the boards horizontally in the main entry way but I don't think that would look any good either........... Re: Floor laying direction 5Feb 15, 2013 7:10 pm I would lean towards laying the floor horizontal. Kitchen is then running the length of the room [better]. OK, the entrance is not ideal that way, but it's better for the majority of the job. I would also consider changing the B/room as well, IF you change the direction, so there is not a visual conflict at the point. Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 31823 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4353 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4328 |
