Browse Forums Flooring & Floor Covering 1 Jan 22, 2013 11:20 pm Hello flooring guru's/experts, I need some help with our flooring as follows: We want to find out what to put on freshly laid prefinished/ presealed kempas board. Should we use a wax to fill the gaps or should we use a polyurethane product and reseal the boards again. Your views would be greatly appreciated. Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6996 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15884 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3271 |
