Browse Forums Flooring & Floor Covering 1 Jan 10, 2013 8:50 am 2 storey house Upper floor and stairs is MDF flooring Which is the best underlay choice for acoustics & softness? Each shop says something different! Slab Poured 30/05/12 Lower Floor Plate High 20/08/12 Upper Floor & Wall Framing 30/08/12 Roof 14/09/12 Lock-Up 13/12/12 Yee haaaaa WE ARE IN & I HAVE A NEW IPHONE Re: Carpet Underlay - WHICH IS BEST - Rubber, Foam or Felt? 3Jan 15, 2013 9:18 pm We were told foam when we got our carpet so went with the high grade foam. Rubber apparently wear's thin and will lose it's cushioning over time. Foam bounces back easier so stops getting such big marks from furniture and remains much more durable.... apparently Blog: http://cbcbuild.blogspot.com.au/ Building Thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=62155 Re: Carpet Underlay - WHICH IS BEST - Rubber, Foam or Felt? 4Feb 25, 2014 12:43 pm there is a thin black rubber that is laid down in areas for sound deadening, then underlay is laid over the top of that. I have laid carpet in apartments that must have the thin sound deadening rubber installed before installing the actual job. felt underlay is probably best interms of sound deadening, however the new stuff is very different from the old stuff, so shop around for it to find the old felt and not the new felt. Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4121 There is nothing in the various codes and standards that puts this requirement on the builder to do. I think that is what you are asking. Don't waste time trying to get… 5 2331 1 10997 |
