Browse Forums Flooring & Floor Covering 1 Jan 08, 2013 11:16 pm We are going to install solid timber floor after handing over. I heard that the standard height for timber floor is 18mm and the batten is another 18mm. So, I should inform builder to leave 36mm for door and skirting, is that right? Thanks. Re: what's the height should I leave for timber flooring? 2Jan 09, 2013 10:56 am hfwangoz We are going to install solid timber floor after handing over. I heard that the standard height for timber floor is 18mm and the batten is another 18mm. So, I should inform builder to leave 36mm for door and skirting, is that right? Thanks. Not all timber is 18mm, it could be 13 or 14mm. You can also use plywood instead of battens. I used 12mm plywood as I had wider boards that had to be full troweled glued. Select the timber and substrate and maybe add a mm or two so the timber can slide under the skirting. you can run a bead of caulk over the gap. Re: what's the height should I leave for timber flooring? 3Jan 12, 2013 7:50 pm JB1 hfwangoz We are going to install solid timber floor after handing over. I heard that the standard height for timber floor is 18mm and the batten is another 18mm. So, I should inform builder to leave 36mm for door and skirting, is that right? Thanks. Not all timber is 18mm, it could be 13 or 14mm. You can also use plywood instead of battens. I used 12mm plywood as I had wider boards that had to be full troweled glued. Select the timber and substrate and maybe add a mm or two so the timber can slide under the skirting. you can run a bead of caulk over the gap. Thanks JB1, is it better to leave the skirting installed later after hand over? Re: what's the height should I leave for timber flooring? 4Jan 12, 2013 10:02 pm That would be the ideal situation, but then it would be your responsibility to install and paint them. I seen my carpenter do it and to make sure the joins are unnoticeable he glued and sanded the joins. I'll speak to your flooring installer once you chosen your floorboard and ask them what height to install the skirting. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15908 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16007 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10684 |
