Browse Forums Flooring & Floor Covering 1 Oct 16, 2012 9:37 pm We have Souther beech timber installed in a nearly completed house that we have purchased. I have been trying to find out a few things before it is sanded and finished as we can still make a few choices at this stage. Is Souther Beech and Australian Beech the same timber? Can the Southern Beech be stained to darken it's colour before it is sealed and would this still look OK? What would people recommend as the best type of finish coating? Why? Should a sealer be used? having built in different rural locations may i suggest that the house should suit the location and needs to be different from homes in town..eg if you will be working… 9 5006 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3282 |
