Browse Forums Flooring & Floor Covering 1 Oct 15, 2012 1:47 pm Can you tell me please how you installed it? How much expansion gap do you need to leave between the floor and walls to allow for the incizo? Can you install this after you lay the floors or does it need to be at the same time? Also, can you please tell me approx how much you paid? I notice the incizo comes in 215cm lengths. TIA the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11838 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 1919 Take a pick with a level sittingo n the slab and a pick with a level sitting on the sill please. This will help us diagnose the issue and therefore a solution. RE,… 8 9407 |
