Browse Forums Flooring & Floor Covering 1 Aug 06, 2012 5:04 pm Hi , I need help as I plan to lay polished porcelian tiles 600x600 post handover. Kitchen ppl confirmed the benchtop hight would be 920mm from slab. Within that measurement there is approximately a 20mm flooring allowance, so the benchtop will be at approx. 900mm from finished floor level. Would 20mm be enough to lay the porclean tiles ? What is the thickness of 600x600 tile? As tiler have to screed the slab before laying the tiles. Is 20mm safe to go ahead? Kitchen ppl charging me around 1500$ to increase the hight of benchtop. Re: Kitchen Benchtop Hight for Porcelian tiles 2Aug 09, 2012 4:42 pm With a 600x600 floor tiles you are looking at approx10-12mm. Allow 5-6mm of adhesive once it is compressed. The screed thats a tricky one. It depends if the floor at that point is a high or low point, also depends on what you are levelling the floor with. You may need to talk to your tiler if he is using a sand cement mix or some form of self levelling compound that can be featherd out.' Hard to give you a definitive answer sorry. Cheers Re: Kitchen Benchtop Hight for Porcelian tiles 3Aug 10, 2012 2:06 pm Thanks Zedman, I had chat with the tiling and they said 20mm is enough to lay the polished porcelain tiles Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15259 Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 12929 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7795 |
