If there is no other option (because the builder doesn't offer it), is this a reasonable option? Or, would tiles, something like this
be better given the circumstances?
Browse Forums Flooring & Floor Covering Re: Anyone polished concrete floors AFTER handover? 2Jul 26, 2012 12:45 am Not sure if anyone has... though a few have had their existing floors in renovations polished. Where you are coming from is where you are going to... Re: Anyone polished concrete floors AFTER handover? 4Jul 26, 2012 1:10 am LOL I just PM'd you wonder if I should post it... nope BTW back OT no reason why not.. so long as there is a consideration for the colour/stone blend prior to the slab being poured. And some en devour to produce a flat ish slab oh and as per usual as soon as the concretors have finished, then cover the new concrete with black plastic for at least 3 days ok ( 7 days better) less cracking. Where you are coming from is where you are going to... The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5153 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17318 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10688 |
