Browse Forums Flooring & Floor Covering Re: pulling up floor boards 2Mar 20, 2008 6:55 pm Yep,
Best way is to buy a long pin punch like this one. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Get a good heavy hammer, and a pair of gloves, safety glasses and ear muffs, and go for it. You need to drive the nail down and straight through the floor board into the bearer below. Hard work, but very effective. Steve Re: pulling up floor boards 5Mar 20, 2008 9:20 pm Most floorboards (if that is the original floor) run underneath the wall frames, so you'll need to run a saw along the edge of the floor where the boards run perpendicular up against a wall.
We stripped the Jarrah floors out 2 demo-ready houses like this - punched the nails through as above, then ran the chainsaw down the edges. Nothing like the recycled look in a new place - they came up great (it was for my mate's place - real boards installed as a floating floor) Re: pulling up floor boards 6May 08, 2008 10:53 pm I have taken apart laminate flooring without damaging it and sell it to others before. My way is as follows:
It is a room of 4m*5m. Take the skirting apart first. Then 3 people take the same row apart at the same time. The laminate flooring kept well and the process was very quick! Re: pulling up floor boards 7May 09, 2008 7:26 pm Rochyjp I have taken apart laminate flooring without damaging it and sell it to others before. My way is as follows: It is a room of 4m*5m. Take the skirting apart first. Then 3 people take the same row apart at the same time. The laminate flooringkept well and the process was very quick! No offence mate, but what is it with you and laminate? To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 375 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1930 |
