Browse Forums Flooring & Floor Covering 1 Jun 13, 2012 10:28 pm Hi everyone We build double storey house. Previously, we planned to have carpet on first floor (bedrooms and game room). However, we now consider to have bamboo floor there. Our builder need to us to confirm the actual floor finish height to the first floor. Someone generally suggested bamboo flooring is 15mm plus under-lay which come up to 17mm…But I’m not sure how thick bamboo floor is a good choice for us … What is good specification for bamboo flooring from your experience? Thanks for your help ! Re: How thick is better choice for bamboo floor in bedrooms? 2Jun 14, 2012 2:52 pm Thickness is no sign of quality. A 12mm may be better than a 14mm, it depends on many factors that not even the people sellin it may be aware of. What brands and where are you looking at bamboo ? Try to stick to a brand name floor OR at least a brand name retailer to assure yourself of a good standard. Here is a link to an article about bamboo and the pros and cons etc written by a well known retailer http://flooringadviceblog.blogspot.com. ... g.html?m=1 CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Hi, Have fun, remember bedrooms should feel relaxing and inviting, the last space you see before sleep and the first you see when you wake up. Make sure it makes you… 6 16067 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7575 That's a bit of a vague question. Either cupboard size is fine. With no real advantage or disadvantage to either, apart from the fact that the 900 cabinet fits more into… 1 868 |
