Browse Forums Flooring & Floor Covering Re: Carpet help, wool vs nylon? 2May 15, 2012 2:00 pm @builderforlife Building inspector and passionate about construction When you need an expert to take a look. Re: Carpet help, wool vs nylon? 8May 17, 2012 10:38 pm CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Re: Carpet help, wool vs nylon? 10May 18, 2012 7:00 am CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Re: Carpet help, wool vs nylon? 12Jun 22, 2012 7:25 am There are some tips on cleaning and also a link to the Australain Carpet Cleaning Institute here on this article: http://flooringadviceblog.blogspot.com. ... r.html?m=1 CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW 1 16172 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6752 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7597 |
