Browse Forums Flooring & Floor Covering Re: Quick Step Laminate Colonial range 21Jun 09, 2012 7:00 pm Sounds great to me, But check what trims & u'lay you are getting. Are they Quickstep scotia & incizio? Is the u'lay the Acoustic u'lay? If its Premium supplied it will be green if it's the Quietstep & it may even have it written thru the middle of it. Branded products are great for easy identification. http://app.premiumfloors.com.au/scripts ... 5.20.1.0.3 Re: Quick Step Laminate Colonial range 22Jun 09, 2012 8:16 pm gizmoe Sounds great to me, But check what trims & u'lay you are getting. Are they Quickstep scotia & incizio? Is the u'lay the Acoustic u'lay? If its Premium supplied it will be green if it's the Quietstep & it may even have it written thru the middle of it. Branded products are great for easy identification. http://app.premiumfloors.com.au/scripts ... 5.20.1.0.3 It says "Scotia" trims, I think it's a standard underlay. Is it worth upgrading to QuietStep or it's not really going to make much of a difference? Re: Quick Step Laminate Colonial range 23Jun 10, 2012 11:10 am We dont install anything on std ulay, quietstep is approx 30% quieter & the salesperson should have given you the option when selling to you, the Quickstep scotia & Incizio should also have been shown & you would know. If you had the time drop in & ask to see them so you know what I am talking about. the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11838 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 1919 Take a pick with a level sittingo n the slab and a pick with a level sitting on the sill please. This will help us diagnose the issue and therefore a solution. RE,… 8 9407 |
