Browse Forums Flooring & Floor Covering 1 Feb 28, 2008 1:14 am Hey guys,
Doing a bit of work on my living room. I have to change those tiles. I was thinking to put in those "snap on" wooden floors. A few questions: 1. Is it really as easy as they say? Im not so bad with my hand but I'm going to be covering my tiles so do you think I should get a professional for this? 2. What is the range of costs per sqm? 3. Is there any special manufacture that you know of? Any and all info will be greatly accepted. Thanks again. K Re: Wood over tiles 2Feb 28, 2008 7:13 pm You probably need to take off your skirting and possibly trim off the bottom of doors. You will still need to use a moisture barrire between as well Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15253 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 399 We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5251 |
