Browse Forums Flooring & Floor Covering 1 Mar 02, 2012 11:04 am Hi, We are in the process of selecting flooring and have decided to got for a solid timber overlay hardwood. It is for a renovation and extension. In the existing part of the house we have baltic pine boards and the extension part will be on a concrete slab. One of the brands that I have looked at is the Hurford "Fourteen" product where the board is 14mm thick. I am interested in this product as they offer a wideboard of 130 and 180. I would be interested in hearing from people that have had this flooing installed - looking for good and bad experiences. In terms of species I quite like the grey ironbark or spotted gum. Thanks! Re: Solid Hardwood Floor - Wideboard in 14mm - Hurford 2Mar 04, 2012 7:19 am I've installed these and other similar boards a few times. They come up great. The two things I would suggest need to be considered are largely for your installer. The sub-floor needs to be level. And the tongue and groove on the board needs to be treated with care during installation. I used a Grey Ironbark in my own house and it is a stunning timber. With those width boards the floor should be trowel glued (rather than just glue guns). Hi All. I'm currently resurfacing the hardwood floors and when removing the old layers that there's a long dark line running across the boards. Does anyone know what or… 0 12770 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15908 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 |
