Browse Forums Flooring & Floor Covering 1 Jan 11, 2012 8:44 pm Hi all Have bought sandstone tiles and been quoted $105 per square meter to lay them Tiles are 18mm 400x400 (there is 40sqm to lay in a diamond pattern) Does that seem on par? H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 2Jan 11, 2012 8:50 pm Sounds high. Do you need a screed? Anything special about laying sandstone tiles? Won;t they wear quickly? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 3Jan 11, 2012 8:52 pm That seems pretty expensive to me. Our tiles are being layed for a lot less than that and they are 300x600 rectangle rectified edge tiles. BLOG: thehousewebuilt2010.blogspot.com (And are still building!) Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 4Jan 12, 2012 7:44 am Casa2 Sounds high. Do you need a screed? Anything special about laying sandstone tiles? Won;t they wear quickly? The are a bit thicker than normal tiles. They will be sealed after laying (already paid for sealing so its not included in the quote). Apparently they need to hire a different tile cutter, but I still think its an inflated price.... The tiles are to be layed on 2x balconies on a new build, and they have already been waterproofed by the builder. We didn't like their tile offerings so have supplied our own. Wasn't expecting to cough up another $6300 to lay them given that laying the basic tiles was included in the house price. H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 5Jan 12, 2012 12:00 pm So, $6300 to hire a different tile cutter! I would get a couple of other quotes. Demolition August 2009, Construction Started September 2009, Completed December 2010 $105 psqm to lay tiles ???????????????????????????!!!!!!!!!! 7Feb 07, 2012 9:47 pm I have been quoted around the $50 per m2 for laying. Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 8Feb 08, 2012 8:13 am Ended up going with the quote - after deducting the costs for the original tiles, its not as painful. Under time constraints (tiling holding up other trades) so couldn't shop around H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 9Feb 08, 2012 3:33 pm That price sounds pretty fair to me. Sandstone tiles normally come in various thicknesess, so the tiler will have to spend time grading the tiles (match the tiles with the same thickness). Then you have to use more adhesive with sandstone than you would with ceramic tiles because of the different thickness. Sandstone tiles can only be cut with an electric wet saw which take much longer than when cutting ceramic tiles with a scribe cutter. Finally the sandstone tiles may need to be sealed prior to grouting. And on top of all that you are having the tiles layed in a diamond pattern. So as you can see there is a lot more work involved with laying sandstone tiles as appose to ceramic or vitrified tiles. Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 10Feb 08, 2012 4:08 pm No grinding was required, sealing and the patterned cut were agreed to as part of the contract, so no change there. H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 11Feb 09, 2012 12:07 pm Always best to get at least three quotes, that way you kow if a price sounds reasonable or not. Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 13Mar 08, 2012 7:30 am Almost done - been sealed, now just needs grouting. Looks fantastic though - glad I went to the effort of getting sandstone tiles. H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: $105 psqm to lay tiles ???????????????????????????!!!!!! 14Mar 08, 2012 8:05 pm cookie_monster Almost done - been sealed, now just needs grouting. Looks fantastic though - glad I went to the effort of getting sandstone tiles. & paying the right amount to have them installed. You get what you pay for... Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7795 Our house was completed 8 years ago. Builder did not leave any spare roof tiles behind. Just found out that one tile is cracked. Wanted to replace the tile but most… 0 2785 1 15766 |
