Browse Forums Flooring & Floor Covering 1 Jan 08, 2012 9:16 pm Hi we have just gone through handover from our builder & up to flooring stage (contracting myself as it is heaps cheaper). Would you put carpet in first or bamboo flooring? PS carpet only in bedrooms & bamboo in all other living areas. Re: carpet before or after bamboo floor installation 3Jan 18, 2012 7:37 pm Hi chickynat, Have your hard flooring installed first for sure. Your carpet layers then have something to finish to and will be grateful. Doing it reverse can cost you more money in terms of another visit by the carpet layers and you run the risk of excess dust from the laying of the hard floor getting on your new carpet. 1st Bamboo (with correct trims fitted to areas adjoining carpet) 2nd Carpet Good luck with your new flooring. CALL 1300GOHARVEY www.harveynormanflooring.com.au Carpet, Rugs, Timber, Bamboo, Laminate, Vinyl & Vinyl Tiles TIMBERMAX Real Australian Hardwood Flooring IN STORES NOW Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4551 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7451 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16759 |
