What is the best way to clean new timber floors? micro fibre mop to clean daily, vacuum for big clean, very dry wet mop?
Is Enjo a good micro fibre mop?
Is vinegar and water good for the dry mop?
Any other advice?
TIA
Browse Forums Flooring & Floor Covering 1 Dec 07, 2011 8:44 pm What is the best way to clean new timber floors? micro fibre mop to clean daily, vacuum for big clean, very dry wet mop? Is Enjo a good micro fibre mop? Is vinegar and water good for the dry mop? Any other advice? TIA Re: Advice on cleaning new timber floors 3Dec 08, 2011 11:03 am Hi melcur, I have had both solid timber and engineered timber floors, and I vac and/or sweep regularily, and then use a damp microfibre mop on mine. I have a spray bottle full of water and a dash of methylated spirits and use that to spray the floor and then mop with the damp mop straight away. It dries very quickly. I also use this method on the tiled areas (bathrooms). Gone are the days of the mop and bucket in this house! I will sweep most days (messy kids), vac probably twice a week (time permitting) and wash when I feel they need it, although the kitchen gets dones often. In the 12 years I had solid boards, and the 2 years I have had engineered, I have not had an issue with using this method. Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: Advice on cleaning new timber floors 4Dec 08, 2011 12:28 pm You guys have the cleaning down pat. The most important thing is prevention. Mats at doors, dogs nails clipped, reduce gravel out front. furniture protectors etc. As regard to cleaning products - most floor sealer lines have a cleaning product that matches the finishes. Don't get sucked into using fancy floor polishes, steam mops etc. Stick to this sort of regime and when your floor does finally start to show wear and tear you can just do a maintenance coat rather than a complete resand Re: Advice on cleaning new timber floors 5Dec 08, 2011 1:50 pm I vacuum the floor, and then go over it with my enjo floor duster. On the days it needs a mop, I use my enjo mop with a water bottle that has some pine o clean. I just spritz and mop over as I go Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Advice on cleaning new timber floors 6Dec 08, 2011 2:10 pm You might want to check the pH of the Pine o Clean. It does two things - compromises the quality of the finish and negates the possibility of doing a maintenance coat on the floor. If you are going to use 3rd party cleaning products then always use pH neutral products. POC has a pH of between 8 and 9.5 meaning that you are adding a alkalinic product to your floor finish. Re: Advice on cleaning new timber floors 7Dec 08, 2011 2:14 pm Thanks so much guys! All very helpful. I was thinking of getting an Enjo microfibre mop but they are super expensive I think so might just get the sabco one from bunnings for starters Re: Advice on cleaning new timber floors 8Dec 08, 2011 2:19 pm I use the sabco ones all the time. I did buy a commercial width one which I use from time to time but at 1.2 wide its a bit cumbersome in smaller rooms Re: Advice on cleaning new timber floors 9Dec 08, 2011 3:11 pm An Australian company called Nature Direct have just released a new easy mop flooring system. It is sensational and so easy to use!! I will PM you details. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4940 |
