Browse Forums Flooring & Floor Covering 1 Oct 15, 2011 4:11 pm We are leaning towards the slimmer solid overlay flooring that you can glue straight to your slab. We want to ensure we are getting good quality, but have no idea what we need to check for or is it pretty straight forward as it is a solid wood?? Thanks for any advice It's MGP 10 which means every length has been machine graded to it's specified engineered strength. It may not look pretty and if you where hand picking your timbers you… 1 363 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98880 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16206 |
