Browse Forums Flooring & Floor Covering 1 Oct 11, 2011 8:00 pm We are having hardwood flooring installed in our new house, spotted gum with tung oil finish. I have been wondering what I should clean the timber with, the man installing the floor told me it's best to use a small amount of metho in water, however I have a Boral brochure on timber flooring & it says not to use metho as it will "degrade the coating & irreversably dull the floor" not sure which way to go? On my tiles I just use a bit of vinegar with warm water, is that a no-no on timber? Building our custom design "Dream Home" Follow my Build - viewtopic.php?f=31&t=46820 Contract Signed - 28/04/11 Siteworks Commenced - 20/06/11 Re: Cleaning timber flooring with metho? 2Oct 16, 2011 12:56 am Broom We are having hardwood flooring installed in our new house, spotted gum with tung oil finish. I have been wondering what I should clean the timber with, the man installing the floor told me it's best to use a small amount of metho in water, however I have a Boral brochure on timber flooring & it says not to use metho as it will "degrade the coating & irreversably dull the floor" not sure which way to go? On my tiles I just use a bit of vinegar with warm water, is that a no-no on timber? The installer should have a good idea, but you could always ring or email Boral direct for their opinion. I would have considered the capful of Metho in 5L of water a good method & its what we suggest to customers. I would have thought the Boral suggestion was for their Silkwood product which has a Polyurethane surface coating, not a tung oil. Re: Cleaning timber flooring with metho? 3Oct 16, 2011 6:59 am I was told white vinegar and water on floorboards. Re: Cleaning timber flooring with metho? 4Oct 16, 2011 9:09 am vinegar and water is what Dh uses on our cork flooring as well. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15921 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4937 |
