Browse Forums Flooring & Floor Covering Floor Tiles 2Oct 09, 2011 2:40 pm Have a look at your local tile shop to get an idea of what you like and what's in your budget. Re: Floor Tiles 3Oct 09, 2011 3:23 pm Check with your builder to find out what ranges are standard. Also be aware that some builders charge extra for laying tiles over a certain size. On my case anything larger than 40cm x 40cm incurred extra tiling charges. House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Re: Floor Tiles 4Oct 09, 2011 3:53 pm Hi Srini, Are you doing your tiles through the builder or getting it done yourself..? if its through a builder they usually have a particular manufacturer like National Tiles, Beaumont tiles, Hynes etc..... Tiles have a very wide range of selection so it's hard to say that one particular tile is better ..... have a browse through the builders standard range....if you're doing it through the builder.... They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9592 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 375 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16553 |
