Browse Forums Flooring & Floor Covering Re: Can I use laminate flooring as a interior roof feature? 2Sep 27, 2011 6:47 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Can I use laminate flooring as a interior roof feature? 6Sep 27, 2011 9:09 am humble Like laying a deck but in the other way up. Nice idea, humble. "Like laying a deck" --> would you have "beams" running under your alfresco roof and then nail the laminate flooring ? Interested in hearing how you plan to do this. The final product is going to look good. Good luck ! cheers Re: Can I use laminate flooring as a interior roof feature? 7Sep 27, 2011 9:24 am Yer. So like laying a deck, we would run 20mm 'beams' across the studs, then using the glue recommended by glosswood and hidden nails, attach the decking. Drill holes in the for the lights, pull them through and we are done. So the entry, portico and alfresco we think. About 30sqm. So should cost under 1.5k. Re: Can I use laminate flooring as a interior roof feature? 8Sep 27, 2011 10:22 am Wow !! that's going to look awesome. I had similar plans ( although the laminate flooring use is your original ). We dont have an alfresco at the moment, so was going to use the Stratco one as base setup and then 'modify' it to give it a timber look. Keep us posted with how you go. Good luck Re: Can I use laminate flooring as a interior roof feature? 9Sep 27, 2011 6:26 pm Sorted, well done all. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 4931 Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 4748 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 18569 |
