Browse Forums Flooring & Floor Covering 1 Aug 15, 2011 10:20 am We glued our timber floor directly over concrete. There were a couple of spots where the concrete wasn't perfectly flat, so it now squeaks a little bit. We are going to drill small holes in those spots ... Would you recommend we inject those and fill with "liquid nails" or just "no more gaps"?
Re: Filling hollow spaces under timber floor (solid underlay 3Aug 15, 2011 10:29 am I've done it before A few times I used liquid nails and last time i used no more gaps. The only problem is I didn't stay in those houses longer than 12 months so I am not sure of the long term performance issues ... Re: Filling hollow spaces under timber floor 4Aug 15, 2011 5:13 pm When you direct stick to concrete you are meant to tap over the floor with a broom stick or similar after laying a few boards and before the glue has set. When you find a hollow spot you should drill a 3mm hole and nail it down with a concrete nail (you get these from your flooring supplier). This is then punched and filled at the floor sanding stage. The nail just holds the board down until the glue has gone off. You are meant to nail all edge boards as well. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Filling hollow spaces under timber floor 5Aug 16, 2011 9:28 am Thanks chippy. We used a lot of micky mouse pins, but in a couple of spots the concrete must have been so bad that nailing them didn't really help. Re: Filling hollow spaces under timber floor 9Aug 16, 2011 1:15 pm "using concrete nails or “mickey pins” nail a row of boards on this line as a holding block, with the tongue facing the starting wall. The nails may be removed after the glue has set. Pneumatically fixed ‘T’ nails are acceptable as alternative to ‘mickey pins’. " Re: Filling hollow spaces under timber floor 10Aug 16, 2011 1:16 pm They are supposed to assist in the "the most successful method of fastening a direct stuck board down whilst it is curing" They are not cheap though... Re: Filling hollow spaces under timber floor 11Aug 17, 2011 12:07 am Over here in the west we don't use nails that are removed. We use 3.3mm diameter concrete nails that get hammered into a pre-drilled 3mm hole. These really bite and pull the board down. They are then punched and filled. They make sure that the board is pulled into the glue and as you don't pull them out they will hold the board down even if the glue bond is minimal. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 ShaneG We have been doing heaps of hybrid floors lately. The hollowness is caused by low spots in the slab or subfloor. No slab or particleboard floor is going to be… 1 10409 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31284 |
