Browse Forums Flooring & Floor Covering 1 Aug 08, 2011 3:46 pm Re: Floor Sanders and Orbital Floor Sanders 4Aug 08, 2011 5:00 pm Yes it is. When we had our floors done the floor polisher had this funny looking mesh screen sort of thingy. This was used to just sort of buff and light sand between the 3 coats Re: Floor Sanders and Orbital Floor Sanders 5Aug 08, 2011 5:09 pm Thanks for that. Which sander to you recommend, belt or orbital? Also, how long did you hire the polisher for? Re: Floor Sanders and Orbital Floor Sanders 6Aug 08, 2011 5:40 pm Drum sand across the grain then at 45 degrees then lastly with the grain. Then you fill all the nail holes and end gaps then you go over it with the rotary for the final sand. Vacuum well. Apply sealer and then top coats. You then use the rotary with the mesh pads between coats. You also need an edging sander to do along the walls. I'm pretty sure that is the process. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Floor Sanders and Orbital Floor Sanders 8Aug 09, 2011 11:04 am Kennards have a weekend deal for a floor sander and edger package. Do you think 2 days would be sufficient for 220sqm of timber flooring? Re: Floor Sanders and Orbital Floor Sanders 9Aug 09, 2011 12:24 pm Probably not. A competent sander may do it, but I think they would be hard pressed, particularly if its lots of seperate rooms with edging. If the quality isn't such an issue then you might do it but I see you've just laid new flooring so I guess you want it to look good. As a guide, my friend who is a floor sanders is doing my floors next week And said it will take about 2 and a half days to sand for 100m2 but that does include steps. Have you considered paying someone so you can be sure you will a good job. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Floor Sanders and Orbital Floor Sanders 10Aug 09, 2011 12:51 pm chippy Probably not. A competent sander may do it, but I think they would be hard pressed, particularly if its lots of seperate rooms with edging. If the quality isn't such an issue then you might do it but I see you've just laid new flooring so I guess you want it to look good. As a guide, my friend who is a floor sanders is doing my floors next week And said it will take about 2 and a half days to sand for 100m2 but that does include steps. Have you considered paying someone so you can be sure you will a good job. Cheers for that. Will split it across two weekends then Yes, have considered paying a pro, but would like to give it a go first. If I stuff up I will then pay a pro to fix it What do you mean by "steps" in: chippy but that does include steps. Re: Floor Sanders and Orbital Floor Sanders 11Aug 09, 2011 1:43 pm Our house is double storey. I should of said stairs. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Floor Sanders and Orbital Floor Sanders 12Aug 09, 2011 1:54 pm Ohhh. I see. Our stairs are very smooth. Do we still have to sand them? Only just lightly? Re: Floor Sanders and Orbital Floor Sanders 13Aug 09, 2011 3:51 pm The stairs still need to be sanded. If they are nice and flat then just a handheld orbital should be enough starting with a heavy grit and working down to finer finishing grades. If stairs have too much variation you need to go over them with the edger first then finish with the handheld. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16535 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17414 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20194 |
