Browse Forums Flooring & Floor Covering 1 Jul 23, 2011 4:07 pm Hi, So I'm considering doing my own floor coverings, the builder has estimated a refund of all floor coverings which works out to a fairly small sum, but that's what I expected. The current plan so far is to buy vinyl planks to cover the main room, entrance, hallway, kitchen and laundry. As from what I've read it will have no issues with moisture. I think this will be relatively straightforward to organise. My current concern is what do I do about the bathroom, ensuite and toilet? All vinyl planks have a wood like look so it may look a little out of place in a bathroom/ensuite/toilet. So I'm considering maybe something like roll vinyl? I'm considering maintenance and price in this decision, and I think that vinyl will be easier to clean that tiles in the bathroom. Does anyone know anywhere that sells vinyl rolls in Melbourne at a good price? I assume Carpet Court? ***? Western Distributors? And if you have used vinyl in your bathroom/shower, what did you do about the wall coverings? The builder had included upto 2M of wall covering tiles for the shower.... Any help would be greatly appreciated. Thanks Re: Doing your own floor coverings? Bathroom, ensuite.... 2Jul 23, 2011 4:21 pm HiTheanonyuser,not sure it i can help.I to am having vinyl plank floors.If you look at my plan you will understand why I have decided to have planks through wet areas. I didn't want three different surfaces coming together in one area, will now have planks and carpet.I am thinking Polyflor summer oak,not sure on tiles for walls,have a look at http://imageshack.us/photo/my-images/534/gab9431b45d4a.jpg/ Re: Doing your own floor coverings? Bathroom, ensuite.... 3Jul 23, 2011 5:12 pm Here are some model pictures if it helps http://www.flickr.com/photos/62785756@N ... 107067065/ I think it will look ok as different floor coverings. My bath is next to the wall, as is my shower. So the wall needs to be covered with something. Re: Doing your own floor coverings? Bathroom, ensuite.... 4Jul 23, 2011 5:25 pm I think you could have planks or tiles on your floors in wet areas. I have been told to make sure slab[ if you have one]is level and smooth Re: Doing your own floor coverings? Bathroom, ensuite.... 5Jul 23, 2011 6:33 pm But what about the wall coverings? Re: Doing your own floor coverings? Bathroom, ensuite.... 6Jul 23, 2011 6:38 pm Like you I am still thinking,I do like the wall panels and tiles for shower. I am having Freestanding bath and walk in shower,I think panels would look nice in my bathroom,as I said not sure I could help Re: Doing your own floor coverings? Bathroom, ensuite.... 7Jul 23, 2011 7:05 pm I found something called "villaboard", it sounds like a low cost solution but I haven't done any more checking yet. Re: Doing your own floor coverings? Bathroom, ensuite.... 8Jul 23, 2011 7:26 pm I will check it out,There is also a polycabonate sheeting can be any colour easy to clean. Re: Doing your own floor coverings? Bathroom, ensuite.... 9Jul 29, 2011 7:30 pm Did some more searching and found this thread: Alternative to wall tiles in a bathroom viewtopic.php?f=21&t=44465&p=761277#p761277 Aquapanel looks like it would be good to use for the bathrooms, I'm hoping installation is not expensive. the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11835 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20420 Hi there I'm looking for a independent company for a expert report on my blinds ,sheers & plantation shutters I'm in Melbourne 0 9226 |
