Browse Forums Flooring & Floor Covering 1 Jan 20, 2008 2:56 pm Hi
Will I be able to easily install floating timber floorboards in the kitchen after handover or as I have just read in an older post a guy was going to get the builder to raise his benches by 40mm to allow for this ?? Cheers Rowan Re: Timber floating boards in Kitchen 2Jan 20, 2008 3:36 pm Im getting the kitchen benches raised by 40mm as I will be installing SOLID timber floors. Re: Timber floating boards in Kitchen 4Jan 20, 2008 5:41 pm rowan Hi Mark Thanks for your response. So floating floorboards shouldn't be a problem but if I decide to have solid floorboards is it absolutely necessary to raise them ? Cheers Rowan The main reason to raise them is to allow adequate space for the dishwasher. Otherwise you would have to install the dishwasher, then install the floor, but then you'd never be able to get your dishwasher out. Re: Timber floating boards in Kitchen 5Jan 20, 2008 8:12 pm I did my kitchen with 1000mm high benchtops which apparently is becoming more popular over the traditional 900mm - washing up is so much better not having to bend into the sink ( of course the dishwasher doing it is still better) Re: Timber floating boards in Kitchen 6Feb 18, 2008 4:56 pm Quote: The main reason to raise them is to allow adequate space for the dishwasher. Otherwise you would have to install the dishwasher, then install the floor, but then you'd never be able to get your dishwasher out. You may choose the 810mm instead of 850mm high dishwasher. Re: Timber floating boards in Kitchen 7Feb 18, 2008 10:51 pm Quote: I did my kitchen with 1000mm high benchtops which apparently is becoming more popular over the traditional 900mm - washing up is so much better not having to bend into the sink ( of course the dishwasher doing it is still better) Good move duke - The population is getting taller every year. Steve ps Good dishwasher use less water too - To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 393 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6141 |
