Browse Forums Flooring & Floor Covering 1 Jun 14, 2011 9:06 pm Was originally wanting 600 x 600 square porcelain tiles however they were way out of my price range. What I could get though was 300 x 600 rectangle tiles laid either in a brick or block pattern. I chose the block pattern (I like simple and symmetrical). I haven't seen any rectangle floor tiles laid and am now second guessing my decision (although too late to change). Will this look okay? Has anyone else done this or got pics? Re: Floor tiles 300 x 600 laid in block pattern 2Jun 14, 2011 9:10 pm Oh the tiles are for our kitchen, living, theatre areas of the house (all the downstairs excluding laundry) Re: Floor tiles 300 x 600 laid in block pattern 3Jun 14, 2011 9:18 pm I have 300 x 600 tiles laid standard.... is that block? Sorry this is the only pic I can find at the moment, it's a bit blurry.... please excuse that feral cabinet... it was a temporary solution. I can take some more pics for you tomoroow if no-one else posts any. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Floor tiles 300 x 600 laid in block pattern 5Jun 15, 2011 11:41 am Thanks Joles and Suh! Both your floors look great. You have given me the reassurance in my decision that I needed. Generally, the texture that you listed will have a 2mm size stone chip in it which is dragged with float to give the lines Any patch work needs to be 2mm less than face… 2 1818 I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8108 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9578 |
