Browse Forums Flooring & Floor Covering 1 May 26, 2011 12:45 pm Hi everyone, Me and the misses have been thinking to outsource the flloring (tiles and carpert) instead of going through the builder to save soem costs (builders mark up) My question is, how does this work? Do the builders give us a credit for the floorings? What happens with the wet areas? In our current contract it only has the main living area and bedrooms with price.. not bathrooms/wet areas, but they are included.. Re: out sourcing tiles instead of going through the builder 2May 26, 2011 1:07 pm You would need to ask your builders. Floor covering in non-wet areas are not standard therefore you may be able to outsource these however the builder may not let you have them laid by their tradies during the build - since they wouldn't be covered under their insurance / warranty. Same with the wet area. First point of call should be to call the builder - better still put it in writing / email so you have a record of the discussion. Some things are worth waiting for. Re: out sourcing tiles instead of going through the builder 3May 26, 2011 1:22 pm yeah i kinda thought the wet areas were a standard item, im happy for m to do the wet areas but in the main living room/bedrooms id rather cut them out and save some money.. even if it means i get the flooring place to come in after handover... Re: out sourcing tiles instead of going through the builder 4May 26, 2011 1:33 pm Some builders will let you take out the flooring componant of the build and get a credit back at the end some builders stick to the guns coz its already in the contract. If they do, you may have to do it after handover. We have chose to do the main areas after handover to save costs, you can save a heaps on tiles and we didnt want to pay full price for quality tiles PLUS the builders margin. __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: out sourcing tiles instead of going through the builder 5May 26, 2011 2:43 pm yeah tell me about, a quote on carpet saved us 50% ... So im sure there is a saving to be made with the tiles also. What happens with the skirting tho? I mean the gap between the skirting and the slab... i dont want a situation where the tile wont slide in under the skirting. or there is a massive gape.. Re: out sourcing tiles instead of going through the builder 6May 26, 2011 2:51 pm Our builder is going to fix the skirtings to all areas that will have carpet. He said that is best to do it before so the carpet can be laid taught. If we put the skirting on after the carpet, we would get warping and ripples in the carpet from stretching along the edges. The tiled ares will be tacked on so we will need to fix after the tiles are down. __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: out sourcing tiles instead of going through the builder 7May 26, 2011 5:45 pm If you organize your own tiles in non-wet areas, and if the slab cracks in a few months after handover (or 5 years later before the warranty expires), and subsequently damages your own tiles, will the builder a) fix the slab + your own tiles or b) the slab only ? Re: out sourcing tiles instead of going through the builder 9Sep 08, 2011 7:18 pm Starz Our builder is going to fix the skirtings to all areas that will have carpet. He said that is best to do it before so the carpet can be laid taught. If we put the skirting on after the carpet, we would get warping and ripples in the carpet from stretching along the edges. The tiled ares will be tacked on so we will need to fix after the tiles are down. Can't see how that could possible happen. But definitely fit skirtings before carpet. I need to replace some lengths of aluminum shower frame but I can't seem to find any suppliers of this stuff. Neither the blue or orange home centers carry these things.… 0 5396 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6271 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105134 |
