Hi, we have a contract on a house and it currently has floating floors, as it is a 2 story house this makes it noisy downstairs.
Is it possible to lay carpet over floating floors without any issues.
Any advice would be great
Thanks
Browse Forums Flooring & Floor Covering 1 May 22, 2011 11:37 am Hi, we have a contract on a house and it currently has floating floors, as it is a 2 story house this makes it noisy downstairs. Is it possible to lay carpet over floating floors without any issues. Any advice would be great Thanks Re: carpet over floating floors 2May 22, 2011 1:14 pm Simply pull up the floating floors. They are not nailed down, they "float". Re: carpet over floating floors 4May 22, 2011 4:54 pm Nope, cant lay over top. The carpet layers would have it pulled up in about 15 minutes. It would be quicker than them pulling up old carpet, so they shouldn't charge you more. Best to not mention my signature... Re: carpet over floating floors 6May 24, 2011 4:20 pm Is the floating floor under the skirting, or is there a scotia around the wall. If it is a timber floating floor,and under the skirting, there may be a slight gap when the carpet is laid after taking up the flooring. Laying over the floating floor raises issues with floor height at junctions of other floors. And if something goes wrong with the floating floor if carpet is laid over it, it will all have to come up. Best to remove it before carpet is laid. But it is not impossible to lay over it, just not recommended. To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 413 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6162 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3012 |
