Browse Forums Flooring & Floor Covering 1 May 21, 2011 7:59 pm We are in the process of doing our first home renovations in our first house which is including doing some sort of covering on the kitchen floor. The house was built in 1970 so has old wooden floor boardoards, we would like to tile but one tiler that we got a quote from said that tiling wouldn't work as the tiles would crack on these old boards within a couple years, another tiler told us we could if we use cement sheeting with a flexible good grade adhesive. We really need some advice on this as we are pensioners and can't afford to rreplace stuff after it is done Any help appreciated Re: Need kitchen floor advice please 4May 25, 2011 9:10 am You guys are funny. Belveder, we have never had a problem (if timber floors are solid) using 6mm cement sheet to lay floor tiles. You will see that the sheet is marked where all the screws should be; don't shortcut. Make sure you screw in at all the points. This should give you a solid base for your tiles. I have been working at a house this weekend that we tiled like this 8 years ago. It's been a rental & the floors are good as new. Edit: For goodness sake don't engage the first tiler. Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15259 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14332 6 55355 |
