Hi
Anyone know if Di Lorenzo charge a premium for 1.5mm grout?
Thanks
K
Browse Forums Flooring & Floor Covering Re: DiLorenzo - 1.5mm grout 2May 12, 2011 10:06 pm Not sure but a better question would be; Does anyone know what does not incur an extra charge from Di Lorenzo? Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: DiLorenzo - 1.5mm grout 4May 14, 2011 7:13 pm I called them today and ............. that will be another $24/ sqm please madam......I also found out you have to pay underlay in wet areas for any tile over 200 x 200 and that is $24.50sqm. And if you would like the same floor tiles on your wall that will be $18.50sqm ! Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not… 2 12898 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5453 |
