Browse Forums Flooring & Floor Covering 1 May 10, 2011 9:05 pm Hi all I am somewhat confused about what underlay we need for our 19mm solid hardwood floors upstairs to reduce noise transmission (especially footfall) to downstairs. We have a timber frame covered in plywood. Can you lay an underlay directly onto that and then secret nail/top nail the hardwood floor? Or is there some other method? Most websites talk about laying onto concrete....not applicable to a second storey. Also, any advice as to which acoustic underlay homeoners have found to be the best value? TIA Loretta Re: Underlay for 19mm hardwood timber floors upstairs 3May 19, 2011 5:00 pm Hi Loretta, In the ATFA manual (and in Boral's too) there is a chapter on laying on particleboard (although a bit confusingly assembled, as it's not clear what to do when) ... Anyway, if you use any "loose" underlay, you then can't glue the boards. Normal practice (for Syd) is to nail and glue. My signature is distracting people from my wise posts ... Re: Underlay for 19mm hardwood timber floors upstairs 5May 25, 2011 2:06 pm Hi all Thanks for all your replies. After much searching, we have decided to go with AcoustaCork. It seems to have lots of great features. Lets just hope it does the job! Will try and remember to report back once we have moved in! http://www.marquesflooring.com.au/index ... =2&pid=138 Loretta I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6294 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8356 Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4046 |
