Browse Forums Flooring & Floor Covering 1 Mar 24, 2011 8:42 am I'm confused about the many different types of warranties offered by many bamboo companies. I know a company in Melbourne that offers "25 Year Structural Warranty" plus "25 Year Wear Warranty for residential". Is this the minimum warranty that I should looking for when selecting a bamboo company for my private build ? 13-08 Moved in 13-05 Build restart 13-04 VMIA compensation 12-08 Builder liquidation 12-03 Fixing 11-12 Lockup 11-11 Frame 11-09 Slab 11-09 Start 11-07 Contract 10-11 2K deposit 10-06 Titled land Re: Bamboo Flooring Warranty Types 2Mar 27, 2011 7:19 pm Hello zeitgeber Is always best ask if there warranty is in fact from there company and not a factory warranty, the factory warranty is hard to claim on, because would you know where there factory in China is. Also ask if they can give you a structual warranty on the board and finish and also an installation warranty. Because most problems happen in the installation part. For example if they don`t put a moisture barrier down first on the concrete sub floor, your bamboo after about a year might start to cup. Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6208 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15923 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6468 |
