Browse Forums Flooring & Floor Covering Re: Vinyl flooring 2Mar 16, 2011 3:57 pm You will probably still need some sort of trim to cover/finish the raw edge of the vinyl on the wall. There is a vinyl wall capping available in various colours that may be a close match to your vinyl choice. This is fitted after the vinyl is laid Or you can fix a timber beading to the wall [10cm from floor] for the vinyl to finish to. Fix this to the wall before vinyl is laid. A 'cove fillet' a required to fit at the floor/wall junction, to support the curve of the vinyl. A good retailer should be able to show you samples of the trims etc. to get an idea of what they look like. Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8358 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15244 |
