Browse Forums Flooring & Floor Covering 1 Mar 03, 2011 1:46 am The New Solid Flooring - Stay Flat Technology The solid timber is made up of three-layers and made of premium grade WA timber that is produced wider and longer. By cross-engineering the product, it allows the core and bottom layers to utilise the less attractive parts of the same timber, leaving the best-looking timber for the top. These new Timber flooring is a wider board 150mm, where I think this width of board would cup if it was just solid. The timber is comes in is Golden Mahogany, Jarrah, Marri, Rose Jarrah, WA Blackbutt, WA Walnut and is pre-finished with 7 coats, so no sanding the floor once it is layed. What are your thoughts on this new timber flooring technology??? Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au Re: The New Solid Flooring - Stay Flat Technology 5Mar 04, 2011 10:07 am asher1 I don't think plywood is new technology. Hello No it not ply, they use all solid timber, for example the middle layer and the bottom layer are also solid timber. Price is around $150m2 installed. Re: The New Solid Flooring - Stay Flat Technology 6Mar 25, 2011 11:22 pm The new stay flat solid timber flooring. Is a wider board, with a cross section also made of same timber with the bottom layer also the same timber, so technically solid. The cross section in the middle going across the board is to give it more strength and prevent cupping. This board is pre-finished with 7 coats of klummp finish. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What do you think about this?? Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au Re: The New Solid Flooring - Stay Flat Technology 7Mar 26, 2011 10:45 am Hope they don't klummp together. Re: The New Solid Flooring - Stay Flat Technology 8Apr 15, 2011 7:50 pm Any more thoughts on this new hardwood flooring system????? Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au Re: The New Solid Flooring - Stay Flat Technology 9Apr 23, 2011 8:11 am Any new technology is interesting if it involves real wood. I'm just not interested in photocopied "wood" floors. With the Klumpp coating how long wearing is it - and are there any solvents in this coating? Re: The New Solid Flooring - Stay Flat Technology 13Apr 25, 2011 2:15 am vanders2 Pre-finished, no sanding required ? Does this mean you get those ugly join lines where each board meets ? Hello Yes you do get the micro bevel edge, but it is the smallest you can get them, also has 7 coats on, where the sanded and finished only as 3 coats. Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au Re: The New Solid Flooring - Stay Flat Technology 14Apr 25, 2011 2:16 am zeitgeber The picture posted is the exact same picture from a WA website lifewoodfloors who sells the StayFlat Technology and also has a background in bamboo flooring. hello zeitgebar Yes you are correct, I`m interested in this product also, and i want to get a idea of what people think? What do u think of this product? Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16265 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8495 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4286 |
