Browse Forums Flooring & Floor Covering 1 Feb 09, 2011 12:27 pm What are the limitations of using the batten fix method of installing solid timber flooring onto concrete? Re: Batten fix OR Direct mechanical fix method? 2Feb 10, 2011 5:22 pm As opposed to what BBB, and which type of timber flooring Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Batten fix OR Direct mechanical fix method? 3Feb 11, 2011 12:25 pm Hi Michele Batten fix as opposed to Direct mechanical fix method. Type of timber flooring: solid/ hardwood timber floor Re: Batten fix OR Direct mechanical fix method? 4Feb 11, 2011 12:54 pm If you are building from scratch and your home is elevated on piers a solid timber flooring is nailed to the foundation of the flooring, so direct nail to timber. If you are putting timber down over a slab, the usually way to do it is on batons to keep the timber off the slab in case of moister which will rot the timber after a while. It’s also best to have a thin timber underlay down over the slab as well. If laying tongue and groove laminate, the same method as above is used. Don’t forget to leave room for expansion of the timber when laying. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Batten fix OR Direct mechanical fix method? 5Feb 11, 2011 1:09 pm So direct sticking isn't recommended at all? Re: Batten fix OR Direct mechanical fix method? 6Feb 11, 2011 1:10 pm Does batten fixing cause squeaking? Re: Batten fix OR Direct mechanical fix method? 7Feb 11, 2011 1:13 pm blueblueblue So direct sticking isn't recommended at all? I would never do it! It doesn’t allow for expansion of the timbers. And what if you need to remove a plank for some reason, you can’t, as it is glued down. No not recommended. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Batten fix OR Direct mechanical fix method? 8Feb 11, 2011 1:16 pm blueblueblue Does batten fixing cause squeaking? I've never heard timber floors squeak…..creak maybe, but that's normal. What you need to watch out for, which is why I asked what timber, is the Laminates. They drum when you walk on them. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5151 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6146 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 5970 |
