Browse Forums Flooring & Floor Covering Re: E-Bamboo Flooring Users 2Jan 27, 2011 4:05 pm There is an article here: http://www.bambooconnection.com.au/bamb ... dvice.html that helps explain the things you should look out for if you're going to buy bamboo flooring, if that's what you're asking? 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6211 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6469 |
