Browse Forums Flooring & Floor Covering 1 Jan 11, 2011 8:46 pm Hi forum and timber floor lovers/experts. If possible I would like to draw on your more than generous advice on timber floors. Can anyone ID the species of wood from these photos? http://img203.imageshack.us/g/8520537.jpg/ Can anyone recommend a reputable timber secret nail strip flooring (19mm x 80mm) supplier in Melbourne? What sort of things should I look out for or questions should I ask when buying timber strip flooring? I am going to be laying 19mm x 80mm over 12mm plywood base. What type/brand of glue should I use in addition to the secret nail? Instead of top nailing the boards closest to the walls (except maybe the first and last boards) is it possible to use a brad nailer through the tongue instead? I am having the existing sealed floors sanded and re-finished. What sort of things should I look out for or questions should I ask/require of the sander? I would like to have as a finish that is - as possible (to avoid that yellowy-orange tinge) - something on which the scratches wont show up as much -preferably not a two pack polyurethane finish (I assume scratches show up readily??). Can anyone point me to any advice on the type of commonly used finishes and their strengths and weaknesses. I realise this is a big ask but any advice you can provide would be greatly appreciated. JT Re: Timber floor species ID, buy, lay, sand and finished 2Jan 11, 2011 10:33 pm The timber is Vic Ash. Use Bostick Ultraset glue Hire a secret nailer Use Bona water based poly Re: Timber floor species ID, buy, lay, sand and finished 4Jan 16, 2011 8:22 pm Both are good options. Treatex is a Hardwax Oil which gives a warmer look to a floor Bona is a water based polyurethane which gives a cleaner more contemporary look interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46973 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17545 2 4356 |
