Browse Forums Flooring & Floor Covering 1 Dec 29, 2010 10:52 am Hi everyone We are building a new home and the builder recommends sealing our matt porcelain floor and bathroom tiles (shower recess). I have heard everything from 'they don't need to be sealed' to 'just seal the grouting'. The builder was charging about $5000 to seal the entire house, but I am very confused!! Any advice would be appreciated!! Re: MATT PORCELAIN FLOOR AND BATHROOM TILES - sealing?? 2Jan 08, 2011 1:09 pm Matt tiles generally don't require a sealer unless they are of a porous nature. If they were polished that may be a different story. Sealing the floor with a penetrating type sealer is a good idea as the grout stays cleaner . I would try to see whther the tile will stain easily . Try to stain a spare tile you have with beetroot,red wine etc and let it soak. If it cleans up with no marking then sealers are not generally required. Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 I asked this question of one of the forum's resident cabinet makers who may/may not wish to identify himself to answer other questions if he sees this, but the rersponse… 3 7710 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8403 |
