Browse Forums Flooring & Floor Covering 1 Nov 08, 2010 4:50 am Hi all, we are building a new home finally YAY... well pre-start is on Tuesday. We aren't having the flooring done by the builders, as we wanted to keep our loan amount as low as possible. Just wondering if anyone has used the Crosby Timber Tiles, or seen them in houses? I really love Timber look, but tiles are so much easier to clean and care for. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Your thoughts or suggestions would be much appreciated. Also... it's best to do the skirting before laying the floors, right? Thanks in advance, Mel Building the Entertainer 195 with Homebuyers Centre at Byford Central in WA... Pre-start: 9th Nov 10 Slab Down: 14th Mar 11 PCI: 19th Aug 11 Handover: 02 Sept 11 Our Build As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17869 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15909 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18300 |
