How much for 12m2 tiling?
However some tilers will charge a day rate on the smaller jobs rather than per mtr, so you might be charged around $500-$600 for the job seeing as it should be completed in the 1 day (unless he starts late in which case he may need to return to grout it in).
If it's porcelain then you could be charged $70-$80/mtr plus they'll have to screed the floor to ensure the levels are perfect
which would be an extra $5-10/mtr. Just be sure the tiler uses flexi glue- all new homes have a degree of movement so to allow for this you need to use the rubber base adhesive to prevent your tiles cracking with the cracks in the floor.
That will be an extra $20/bag but there are some tilers out there that will charge you the extra but then they use the cheap regular glue. Best to buy the glue yourself & ask the tiler to provide labour only.
Hope that helps
Suzy
Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$…
4/11/2023
Hi, I'm clearing the tiles from our horrid 50 year old bathroom and preparing to lay new ones. Bugger of a job getting the old…
