Browse Forums Flooring & Floor Covering Re: which building company do Timber Floor Foundation in Mel 2Sep 24, 2010 4:28 pm Our builders, Yarra Valley Homes only work on stumps, and build anywhere here is what they have done for us so far. viewtopic.php?f=31&t=38733&p=577136&hilit=glenrowan#p577136 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7509 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16134 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3363 |
